TractorLinks.com
276 baler - Overriding clutch issue
dhermesc
06-11-2018 06:38:07
Got the flywheel on and off and now the shear pin issue has gone away. Apparently it was masking an issue with the over riding clutch for the pickup (super sweep). I run this baler in "moderate" windrows and I move fairly slow (1 or 2 with a D17). If the windrows get a little heavy the over riding clutch starts to slip stopping the pickup. The 276 manual gives extremely little information about adjusting this clutch (in fact it primarily says to "adjust it"). Check the online manual for a 278 and it gave a few details on how to adjust - "tighten" the 8 bolts on the clutch.
How much "adjustment" do you get by tightening these bolts? I tighten them all about 1 and 1/2 turns the issue got better but in the rough ground I am in (waterways) the pickup stopped a couple times when the tines scraped across the ground.
Hay hay hay
06-11-2018 13:15:29
 Re: 276 baler - Overriding clutch issue in reply to dhermesc, 06-11-2018 06:38:07
My 276 pickup was slipping and finally "stopped" locked up. After taking of the pickup guards we found that the cam bearings were wornout, some had no roller, others locked up. They are hard to get to for an old guy. I just put 6 new rollers into the supersweep and it seems to be freed up and working OK.
You might first see if the pickup moves freely or locks up before adjusting the slip clutch.
dhermesc
06-13-2018 05:25:59
 Re: 276 baler - Overriding clutch issue in reply to Hay hay hay, 06-11-2018 13:15:29
Thanks. Will check this out.
