Plow identification
Casenutty could identify if he was on... It's an older model,equiped for the eagle hitch. Probably from the 400 days.I had one,a newer model(4 bottom,16"). was a good plow. Problem is there are NO consumeables available anymore. No aftermarket makes left side parts.If you cant find any 'new/old stock',you're out of luck.I couldn't.Thats why I sold mine.Right side parts are still available from Shoup and other scources.
That is it! Thank you. The main shaft that where plow mounts and rotates the plows has failed it is pulled out (away from the back of the tractor) about an inch and the main bearing in the front appears to be broke. The sprocket that rotates this main assembly is now pulled flush against what is left of the bearing. I will probably not find the parts to fix it.
Thanks for helping identify it.
