Help identifying a mower
tiberius30
New User
Hi,
I bought a used finish mower. It is blue and says "Superior Gear Box" on it. I have already emailed the company, but in case they can't identify it, does anyone know what it might be? I saw where someone asked a similar question, but I don't think it was answered.
Thank you,
Chris
Superior is the name of the gearcase only. They make them for many companies.
Don't have a clue as to mower manufacturer.
You have either a Ford 930 or 930A mower. Spindle bearings and spindles are expensive to repair if worn out. The one bearing has the seal made into the out side of it.
(quoted from post at 20:51:47 06/08/18) You have either a Ford 930 or 930A mower. Spindle bearings and spindles are expensive to repair if worn out. The one bearing has the seal made into the out side of it.
Thanks, that is what I thought it was. The spindle is fine. One of the belts busted. Took the other off to match it. I am hoping tractor supply will have one tomorrow.
Chris
