I have a bale wagon that after the second table brings hay up to load rack the hyd. check valves at the end of that line that feeds that lift cylinder will sprits oil out..I recently replaced those with new ones from dealer.. also have replaced hoses..any suggestions..
Works good other then the quick sprits of hyd fluid out that valve.. manual doesnt go into alot of detail about that
Has both releif valve and check valve plumbed into the shaft end of cylinder..
any thoughts?? thanks in advance
