sfcrusscanter
I thought I would make it rain so I started cutting hay... The top roller bearing on the PTO side went out and the chain also broke. I've gotten the chain parts, so now I'm trying to disassemble the sprocket and then pull off the old bearing race. After a couple hours of working on it, I still haven't been able to get the Gibbons key out. There isn't much clearance to use the gear puller I have to pull the sprocket. Any ideas? I'll see if I can load some pictures.
Russ, in Kansas...
Russ, in Kansas...
