205 gyramor rotary blades
I have a question about a part number for a JD 205 gyramor rotary cutter. I recently picked one up ans i wanted to swap put the blades because the current ones seem really dull even though they do cut. On JDPARTS it has part number W39207 and when you do a basic google search for blades for a 205 rotary cutter the part number shows up as W34286. So I am not sure what part number is correct.
(quoted from post at 20:20:31 06/04/18) If I remember right the nuts are backwards threads. There should be several different options in the way of blades. Tom
Yes there is 3 different blades but i have comflicting information on the correct part number for the flat blades.
JR
(quoted from post at 23:20:31 06/04/18) If I remember right the nuts are backwards threads. There should be several different options in the way of blades. Tom
According to 205 parts catalog series 001 blade nut had RH threads & series 002 blade nut had LH threads. W34286 when entered into JDparts cart subs to W39207. Take note of the A&I part number(A-W34286 ) in my photo.
