5100 Drill Opener Bearings
pcrh
Hi:
I have a CaseIH 5100 seed drill and need part nos for the opener bearings. These are the double disk openers, if that matters.
Thanks
The bearings alone without the housing are FIAT/dba CIH part number 87302841, less than $10 at the dealer.
For aftermarket, GOOGLE "6203-2RK Radial Ball Bearing".
There's some pretty cheap ones on fleabay and other 'net sites.
Hi:
Went to the local store to find the bearing. They have the 6203 bearings but they are 6203-2RS and not the 6203-2RK bearings.
Is there a difference?
(quoted from post at 08:42:00 06/04/18)
Hi:
Verify that the inside diameter is the same.
If so, difference is likely in the seals.
