I have intermittent tying problems with my 24T baler that, when I check the troubleshooting section in my manual, could be caused by tucker fingers not being adjusted correctly. I"ve made the adjustment, but there seems to be a lot of slop/play in the tucker fingers. How tight should things be if parts weren"t worn? The fingers themselves have some play on their shaft, and the arm ends have a lot of play where they pivot on the fingers. Also, should the arms be straight and without bends? Just wondering if too much looseness in the tucker finger mechanism can cause problems even things appear adjusted correctly? Thanks for the help.
