We've had a 15' 210 JD disk for over twenty years. It seems like it needs repairs about every 40 acres or so- mostly gang bolts and gang bolt bearings. The gang nuts will loosen over time as well, but we have mostly fixed that by adding a second nut to the gang bolts to prevent them from loosening. The front gangs have three bearing standards, and the back only have two. Would this implement become more reliable by adding a third bearing standard to the rear gangs? Does anyone have any ideas for making this disk more durable? It has the regular standards, not the rock flex.
Thank you for any help!
Lon
Lon
