8575 bale eject
youngin
I have no manual and trying to eject last bale and any other tips on operating the machine. I know nothing.
Thanks
Not trying to be nasty but you have an 8575 big square baler and are trying to run it with no book? Do you even have a monitor? At the price of parts get a book before you even think of using it. I have helped the neighbor on his some and it is not an oversized small square baler. I will tell you that the bale eject does not work real well. Neighbor tries not to use his if he can keep from it but will often bust a bale of dry hay and rebale it to empty the chamber when doing hi moisture hay. Tom
I went to the dealer yesterday they had no book but he printed me out a bunch of pages. I used my round baler to finish but I still can't get the last bale eject to work. The cylinder is extended but will not retract. I hear the celonoids click but no moving cylinder. The partial pages I have says how to eject but if the ejector does not function correctly see ejector control valve attachment in the maintenence section. Well I don't have that section.
So I got the ram to work. I didn't have
my hydraulic lever in the tractor locked
in. I got a baler ejected but is their a
way to get the bale out that is being
made? It will not pull out because it's
not made completely.
