Question for PMS in Arleninor
Hay hay hay
When using your haybobs, Looking for some practical experience. Do you both Tedd and rake with the same machine? If so do you change the
settings on the tines between Tedding and raking as the manual suggests and/or does it make any significant difference ...?
I change mine unless the hay is light. Putting it in the ted mode spreads the hay out more uniform. In rake mode will ted also but will tend to make a windrow in the center and leave hay on the edges. Not a problem if using a side delivery rake.
