I bought a good ol' JD 851 hay rake at an auction a bit back. I finally got some time to check it over and try to get it working. The lowering assembly to drop it to down and run the clutch was missing so I put a hydraulic cylinder in its place and that is working great. My issue now is while engaged something is binding up and stopping the rake from running as I go through the field. I can stop, back up a bit and go again and that clears it up most of the time, but this won't work for me as I need to be able to rake my hay field with it. I am looking for two things, the setup/operation manual and if anyone has any ideas on where to start looking to figure out the binding issue that would be great too. Thanks!
