The manual says, that the twister hook should be on top of the twister rod and pointing at the back of the bailer when starting the twisting mech.
It says that after the hook makes 1 full revolution and comes up back at around the 11 00 position, that THAT is when the wire cutter should cut the wire. Adjust the cutter to that point.
Ive done that. BUT, when the twister hook has made the rest of its revolutions, it ends up at 180o difference from where it started. At the bottom of the rod and facing towards the front of the bailer.
Does that mean I still havnt got something right, and if so, what should I do to fix it,
OR
that that IS where it SHOULD end up, for all succeeding ties?
IF that's where it should end up for ALL succeeding ties, then It SHOULD bale. IF NOT, I don't know what to do now.
OR
