International disc
jm42
Can you folks help me identify the model of this old disc. Axle looks strange to be a 37
Ford. Someone put IH decals on and painted it red.The one I had was blue. Older ones may have been red.
When you say axel, do you mean the long shaft the disc mount on? I believe it is called a abour bolt. On my old disc it is a length of square shaft, with a square head on one end , and threads and a nut on the other. If this is what you are looking for, take the pieces you have to most any equipment dealer that sells tillage parts, and they will be able to match up another one for you. These bolts are really not all that pricey.
The shaft the wheel assembly mounts on is what I was referring to as the axle. It extends out much farther than the ih disc does.
Sorry , I miss read your original post. I think your disc could well be a IH. Equipment companies were always buying equipment they did not build themselves , and putting their paint and brand name on to them good example would be the early CaseIH round baler, built by New Idea.
The tounge on my slightly larger IH disc, has a screw type adjustment. Your disc could have come with the same type of hitch, and was changed some time over the years. Thank you for posting this picture, because the hitch on my disc is worn out, and looking at your picture gives me a idea how to rebuild mine.
Here is a picture of my disc, little bigger, but still much the same. Bruce
