Danny Prosser
Morning friends. I had one given to me and I'm trying to fix it up. First thing is are parts still available for this model? I've found lots of other models but not that particular one. The blades wobble up and down so either the bolts or the holes in the blades has worn out. I figure I can match them up if I can get them off. I also need to remove the gear box to do some welding. Anybody know any tricks or good way to get the whole stump jumper and blades off? I just don't see any easy way to use a puller or something so I thought some of you guys might now of a miracle cure or something. It's a real well built and heavy made cutter and a lot better than the thin cheap stuff. Thanks for any help.
