3 point hitch post hole drill
ditchwitch
I bought a used Post Hole Drill at the sale . I need a gearbox. It is a Lienbach Brand . I am having a little trouble locating someone that sells parts. This one has a 1 1/2 output shaft smooth all i can find seams to be 2 in output shafts . This is for a small tractor for my Massey 135 so under 45 Hp post hole drill. Any help appreciated.
Have you checked Surplus Center? If all you need is the shaft but the gears are good a machinist should be able to turn a shaft. Or they could make an adapter from the 2" gearbox shaft down to the 1 1/2" you need.
AaronSEIA
Hi, Leinbach Machinery closed and has been out of business for several years. Don?t know if they made their own parts or sourced them from someone else.
Thats probably what i will have to do. It came with 2 augers 8 inch and a 12 inch and with several bolt on new cutting heads. I actually to
have a good friend that is a machinist.
