Ok so here is my question, has anyone
converted or fabricated their semi-mount
plow to pull on-land? So what I am asking
is. Still using the semi-mount hitch to hook up to the tractor but the tractor would ride completely up on the unplowed ground, right side tires would not be in the
furrow.
I have seen this before once. It was in a
video online, but unfortunately it has been
removed so I cannot reference it anymore.
To me it would make pulling the plow easier on the tractor and take less setup out of
it. Such as rear wheel spacing and such. Being I am relatively new to using a semi-
mount plow. I understand the basics of
using a plow, or at least I think that I
do. I get that there is a science to
plowing and it takes a lot of time to get
it right and plow correctly. Also depends on soil type and ground conditions. I just thought
it would simplify it some, but maybe not. I guess it depends how much work it would take to set it up to on-land. My example of equipment I will be using is a: 1850 diesel pulling a semi-mount oliver #566 5x bottom plow. Thanks in advance....
furrow.
