Pics of my 140W Case bailer tie mech
Farmallb
I took pics of it as I put it back together. There were grooves in the notch on the R side of each. My boy welded them up last night and I ground them back down smooth. IF YOU WOULD, look at the pics and see if/what you think I need to adjust. It cuts fine, and did so before I welded out the grooves, BUT it dosnt make a crimp in the wire, as the manual says it should.
