TractorLinks.com
Inner Shoe Wear Plate
Briar Hill Brittanys
03-12-2018 06:08:05
To keep from hijacking SVcummins post on Haymowers, I posted this. I'm refurbbing my JD #9W mower. When reassembling the inner shoe, I discovered a missing wear plate on the inner shoe, under the front guide. I have a #9 mower for spare parts, and the plate was missing from it as well. Part number H24379 is still available from JD, price is $30.93. Wondering if anyone knew the thickness? I could probably make quite a few for $31.
03-12-2018 20:15:33
 Re: Inner Shoe Wear Plate in reply to Briar Hill Brittanys, 03-12-2018 06:08:05
Appreciate the replies. Thought they could be made from some 1/4" diamond plate. The mower probably only sees 12 acres a year, would they wear out that fast? I believe it's been missing for the 4 years I've owned the mower.
SVcummins
03-14-2018 12:52:55
 Re: Inner Shoe Wear Plate in reply to Briar Hill Brittanys, 03-12-2018 20:15:33
The worst you can do is try it if it donít last like you think it should you can always buy one . I probably wouldnít use diamond plate because itís kinda hard to work with
SVcummins
03-12-2018 20:48:33
I just looked at an aftermarket for my mower and it I 70$ so the John Deere part is a better deal
donjr
03-12-2018 17:52:58
When I wearer one out, I use a hunk of truck spring to build a new one. They wear for a LONG time.....
rrlund
03-12-2018 11:58:26
If you're just using ordinary cold roll,you'll be making a lot of them. They won't be hard enough and will wear out pretty quick.
old
03-12-2018 09:08:03
Well if it wasn't buried in a black berry thicket I could go out and measure the one on my JD #9. But I have not used it since I let a friend use it and he lost the inner pitman arm mount
carvel minne farmer
03-12-2018 07:55:26
briar I just built one out of 1/4" plate for my ih-100 that was missing.
DeltaRed
03-12-2018 06:29:29
1/4" or 3/8.I think $31 would be cheap compared to all the labor involed. It's more than just a flat chunk of steel with a couple of holes.
