Case 2 Bottom Plow ID
sresites
I just purchased a Case plow that I have yet to pick up. Could someone identify it with the following pics? Regards, Steve
This was somewhat mentioned on another forum:
Jointers (scrapers) were especially designed for sod. They turned that edge of sod under so no green was showing on top. They were also the forerunner to coverboards which were much more user friendly than jointers.
That is not for as a scraper and is called a jointer. It is to turn a bit of the trash over to make it completely turn under when the furrow slab is turned over instad of a bit of trash stiking out on top. The curved disk Type of coulters made by Yetter replaced a lot of them and they would keep corn stalks from wrapping around the beam as the jointer was supposed to do. It is not to act as a scraper but a covering unit.
I think it is a model MRB, but not real sure. Go to the left side of the Form and look under Implement Photo, do a search at the bottom of the
page "Case Plow" and you will fine what you have, or a expert should tell you if I am wrong.
I believe it is a model MR plow as it has the pivoting bar for Eagle Hitch tractors. The MRB was the next model that
was almost identical except the bar was rigid for true 3 point hitch. It is not a break away plow like the BER or M
plows however. It instead has shear bolts in the vertical beams of the bottoms. The plow has the newer EX bottoms
that are much easier to find and replace these are sometimes referred to as economy or "throw away" bottoms. If i
remember correctly that plow was down in Missouri? It is a nice find with the original coulters and jointers. Do not
lose them or beat the old work horse up please.
I’m looking for these parts for my Case MR plow. Any chance someone might have this from a parted out unit?
