Bush hog squealer SQ720 manual or specs
bac078
New User
So I picked up a used bush hog Squealer SQ720 yesterday for 550 I felt it was a steal as it was in very good shape So now I am trying to do things in reverse and find the specs on it or see an owners manual After having bought it. Anybody have any help on this I see the BH SQ 72 which may be a newer version Anyone know where to look for this info I called BH and only got a please leave a message havent heard from them yet
Web site says they've discontinued the online manual for the squealer series. Can't say as I blame them. I had one and can say not one of my better purchases . Had shear bolt instead of slip clutch. First time out if I mowed over a heavy fescue patch, POW. If your gonna mow the yard it'll be ok. Good Luck.
im only using it to mow light pasture areas and maintenance around our campground area of our farm. so I figured it would do good for that. Just wasnt sure about the gearbox hp rating and approximate weight of this thing. Best i can find there was an sq72 older, sq172 newer. And sq720 in the middle i guess. I have found specs for the previous two, just not for this one
I see there are some Operators Manuals for it on Ebay. I have the next size up which is an SQ840. The part number for the manual is 50017865.
There?s nothing wrong with a 720 for cutting grass and pasture maintenance. Use the uplift blades part number 7556. They are heavier than the
flat blades and will pick up the wheel tracks better.
