3 point sisor lift hay spear question
I've got a 3point hitch sisor lift thats goes on the rear of my farm tractor and attaches to a hay spear
How well do they work?
Can i stack my 4x5 round rolls of hay with it?
Ive been told that you can stack round rolls of hay with it.
Thanks
I picked one of those up a while back haven't had a chance to mount on any tractor yet,hope it'll keep me from having having to have loader tractors spread all out.
I bought 1 at an auction a few weeks ago to resale ( I have a loader on a tractor and a skid steer) but I've heard that you can load bales onto a deck over trailer so it would probably stack bales 2 high at the most. Any more would make it raising (on 4x4 bales) probably 10' high at a minimum & I just don't see how it could do that let alone the weight distribution on a small tractor could make it awfully light in the front end. It seems to me that a hydraulic cylinder on it would almost be a mandatory thing when trying to load or stack with one. Now these are just my thoughts and please don't take them for gospel. Keith
(quoted from post at 22:18:06 02/11/18) I've got a 3point hitch sisor lift thats goes on the rear of my farm tractor and attaches to a hay spear
Thanks
Yes one can stack rd bales with a rear scissor lift BUT it's difficult to determine correct placement of bales. As I age my neck doesn't seem to rotate as well as it did yrs ago.
It's just so you can stack 2 high on the ground, or one high on a trailer. Might need to make your three point linkage adjusted. 'Up' to get there, depends on the tractor.
Paul
I've used one a few times, good for loading on a wagon or trailer but unless your tractor is 7 feet tall it would be tough to stack a 4x5 on top of another one. BTW they will pinch your fingers off when trying to hitch up, watch out!
<image src="http://forums.yesterdaystractors.com/photos/mvphoto10632.jpg"/>
I have one much like the one pictured. I tried it on about four different tractors . It works ok on the 656 and the 170, not so well on a 544 Utility or the 5065E. It'l lift a 4X5 bale over the side of a pickup truck if you stab the bale as low as possible. I've picked a bale off the second tier, never tried to stack bales with it. Glad I only have $100 invested in it. Even tried removing the cylinder and using a short top link there. Might of increased height a bit.
I have one. As some posters have mentioned, they don't seem to cost "a lot". I purchased a 'homemade" one built very heavy for $150 a few years ago and probably could have worked the guy down some if I were so inclined. It is a struggle for one person to mount and unmounts it. in any event, I view it as very cheap insurance if the loader tractor is out of commission for any reason and I need to move rolls.
