TractorLinks.com
Re: Cutting a drill in half
rdandersom
02-09-2018 14:13:55
I've seen pictures that had 1 wheel and 3 point hitch.
Leroy
02-09-2018 14:34:08
 Re: Cutting a drill in half in reply to rdandersom, 02-09-2018 14:13:55
That could not have worked as the ground wheels control depth that a 3 point connot hold that close to a quarter inch in heigh or position.
SVcummins
02-10-2018 09:56:47
 Re: Cutting a drill in half in reply to Leroy, 02-09-2018 14:34:08
It actually works really well the springs on the openers control the depth of the seed
Leroy
02-10-2018 16:30:07
 Re: Cutting a drill in half in reply to SVcummins, 02-10-2018 09:56:47
All drills I have ever seen have a wheel at each end to carry the frame and from the frame the openers are set to depth and without those end wheels setting the frame height a 3 point will not hold a depth as should for that, same thing that a 3 point cultivator does not hold a perfect depth. That is why later 3 point cultivators have depth wheels on each gang.
SVcummins
02-10-2018 16:41:14
 Re: Cutting a drill in half in reply to Leroy, 02-10-2018 16:30:07
We donít have end wheel drills around here only press drills I would never want one after having a drill with press wheels
Leroy
02-11-2018 08:36:58
 Re: Cutting a drill in half in reply to SVcummins, 02-10-2018 16:41:14
Think I have seen one press wheel drill in my 74 years. Under some conditions the end wheel drills that have a press wheel behind the opener would be good but not in all planting conditions. That I would think has to be used in very dry planting conditions that we don't have around here usually.
SVcummins
02-11-2018 16:22:39
 Re: Cutting a drill in half in reply to Leroy, 02-11-2018 08:36:58
The little press wheels don't like much moisture that's for sure . I can be drilling and be fine when those little plastic wheels can't go
Leroy
02-11-2018 21:06:13
 Re: Cutting a drill in half in reply to SVcummins, 02-11-2018 16:22:39
The amount of moisture in ground here in drilling usually would have those wheels packed sollid with mud.
