Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: McCormick model 21
pburg
02-09-2018 12:13:25
I've had several Mod 200 IHC spreaders, and your Mod 21 looks similar to the 200. In fact I've
never heard of a "21" spreader. I know that there are several suggestions given here. But don't
do any modifications until you're sure of what you're doing. Yes, your tire tread is wrong, but
all you have to do is switch the tires around---L to R, and R to L. No big deal. The two levers on the front---One simply engages the beaters. The other engages the floor mechanism--AND controls its
speed, depending on which notch you have selected. I usually use the fastest speed while driving
about 5mph. This speed will do a good job of shredding the poo, and throwing it a good distance.
There are lots of grease fittings---make sure you clean the zerk (grease fitting) before you put
the grease gun to it. A well-lubed spreader will last a long time. Don't over-look lubing the axle
bearings. If you have more questions about your spreader, I'm willing to help.
