TractorLinks.com
Re: Flywheel RPMs for a W 140 Case bailert
DeltaRed
02-09-2018 11:36:24
Look at your wire.It should be a clean slice where it is cut. If not,there is your problem. The anvil and knife get worn,they get grooved and wont cut the wire. Instead it tears/breaks it.And then it wraps it around the twister.Look closely for grooveing.There should be NO MORE than 1/2 the diameter of the wire gap between the knife nd anvil. A good rub (zero gap) is even better.RPM makes absolutely no difference.As was said,OIL is your friend. Dump a full quart on each coil when you put it in the baler. Reoil at each cutting or if it sets for any length of time.Used oil is acceptable.
