Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: McCormick model 21
Leroy
02-09-2018 07:37:18
The speed of the apron is controled by yhe ratchet on the rear axle in if one tooth at a time or 3 teeth or 5 teeth and that is set by the multiple notches on the lever. DO not use untill you get it put together before you are looking for a different spreader. Yes apron speed will change by how fast you pull it and also beater speed but to cordinate speeds for unloading it is from the ratchet on the wheel, Even some of the older PTO powered spreaders used that ratchet on the wheel to power the web while the PTO only powered the beaters. And then the only speed adjustment on the beaters was how fast you ran the engine on the tractor.
