TractorLinks.com
Re: McCormick model 21
Bret4207
02-08-2018 06:14:38
Don't worry about the "fire hazard" of the waste oil. Unless you intend to park the spreader over a camp fire that is! It isn't going to make a singling solitary bit of difference if the thing catches fire. I'd spread the days manure since you aren't using a tractor designed to pull heavy weights. Better to spread a little more often than to bust the ATV (that would be my big concern) or the spreader. You spend an hour unloading a spreader by hand so you can get to that broken apron chain and you'll know what I mean. That particular spreader style does a good job on bedding with the double shredder set up. And they tend to spread very evenly too. As far as the tires, there probably isn't much real world difference as far as what you're doing. Traditionally, the tires would have the open part of the "V" facing forward when they contact the ground in a ground driven implement using bar tread tires.
