TractorLinks.com
Re: McCormick model 21
Leroy
02-07-2018 21:54:21
There should be no speed adjustment on beater or wide spred paddles, only on the web that carrys the load to the beaters, If you cannot see how it is cleaning out carry a good flash light with you to check at different times.
solo498
02-08-2018 14:29:53
 Re: McCormick model 21 in reply to Leroy, 02-07-2018 21:54:21
There is definitely an arm that not only turns the spinner/beaters / paddles ( which ever you want to call them) on and off but it also has eight notches into which you can set the lever. The other lever has only an on and off notch. This lever locks or unlocks the apron. Of course the speed of the apron is controlled by how fast you pull it.
Leroy
02-09-2018 07:37:18
 Re: McCormick model 21 in reply to solo498, 02-08-2018 14:29:53
The speed of the apron is controled by yhe ratchet on the rear axle in if one tooth at a time or 3 teeth or 5 teeth and that is set by the multiple notches on the lever. DO not use untill you get it put together before you are looking for a different spreader. Yes apron speed will change by how fast you pull it and also beater speed but to cordinate speeds for unloading it is from the ratchet on the wheel, Even some of the older PTO powered spreaders used that ratchet on the wheel to power the web while the PTO only powered the beaters. And then the only speed adjustment on the beaters was how fast you ran the engine on the tractor.
