TractorLinks.com
Re: McCormick model 21
solo498
02-07-2018 19:58:42
So paint the floor and inside walls with waste oil or diesel fuel ......this is a more efficient method that protective paint ?? Wouldn't waster motor oil or diesel fuel be an fire hazard?? It is completely under a roof with only wall not enclosed. But the unit is a always from there. I checked the specs on my Kubota 500. It is rated to pull 1200 pounds. It also has four wheel n two wheel drive : has high , reverse , and liow ,,, it also willl allow me to look the differential in.....I'm reallyyyy hoping it will be okay !!! So far it has but I've no where loaded iit full. If necessary I do have a large dodge 3500. :) Any idea of ideas for protecting the chain . Slats and gears ??? Thank you so much
Hay hay hay
02-07-2018 20:22:45
 Re: McCormick model 21 in reply to solo498, 02-07-2018 19:58:42
The oil soaks into the wood. I've never worried about fire. Paint will just flake off. You might try deck oil or thompson's water seal if it makes you more comfortable.
Kubota 500...ATV? Whoa!!!! The tongue weight could be a serious problem. When my spreader is full to the brim...3 stalls...it puts a lot of load on the tractor drawbar. Best you use the pickup, rather than break the rear axle or frame of the ATV. Just my opinon,...The ATV guys can give you better info on that.
