TractorLinks.com
Re: McCormick model 21
Leroy
02-07-2018 12:46:34
Ground drive should not have a gear box, only the PTO models. For your other question how much does the manure settle and pack down if it sets for a few days? if it does not settle and pack wating will not make buch difference. Only thing will be it getting too heavy for your outfit to pull. Power + traction. I think you need a smaller spreader or something bigger to pul it
solo498
02-07-2018 18:43:47
 Re: McCormick model 21 in reply to Leroy, 02-07-2018 12:46:34
Hi and thank you The manure is not compacting super tight I don't think. Since I'm able to spread it across a larger area of the box and pack it down to get it to fit. It does look that it might be getting jammed tween the chain apron and the wall. Since I've only been able to dump it at night since I've gotten it , I might not be rolling the apron enough times around the box to get it all out. I can't see it until I get it back to the barn. I will see more on that this weekend. The spreader in kept pretty much out of the weather. It's under a large porch of my barn
There are several notches on the wheel of the arm that locks the beaters and paddles. These notches control the " speed " of which the beaters n paddles turn (??) where do I want these set ?? I could understand the chain apron needing control for what's on it ( less drag ) but I don't understand the beater n paddle speed. I tend to think you're right I need a smaller spreader but can't afford one. I was supper lucky to find this / it's super how it actually cuts the manure n hay up before throwing it. My old one only had paddles on just slung it. Worked okayish. Needed rain or moving to remove the manure puds. With this machine it's way more effective with the "pods "
Leroy
02-07-2018 21:54:21
 Re: McCormick model 21 in reply to solo498, 02-07-2018 18:43:47
There should be no speed adjustment on beater or wide spred paddles, only on the web that carrys the load to the beaters, If you cannot see how it is cleaning out carry a good flash light with you to check at different times.
solo498
02-08-2018 14:29:53
 Re: McCormick model 21 in reply to Leroy, 02-07-2018 21:54:21
There is definitely an arm that not only turns the spinner/beaters / paddles ( which ever you want to call them) on and off but it also has eight notches into which you can set the lever. The other lever has only an on and off notch. This lever locks or unlocks the apron. Of course the speed of the apron is controlled by how fast you pull it.
Leroy
02-09-2018 07:37:18
 Re: McCormick model 21 in reply to solo498, 02-08-2018 14:29:53
The speed of the apron is controled by yhe ratchet on the rear axle in if one tooth at a time or 3 teeth or 5 teeth and that is set by the multiple notches on the lever. DO not use untill you get it put together before you are looking for a different spreader. Yes apron speed will change by how fast you pull it and also beater speed but to cordinate speeds for unloading it is from the ratchet on the wheel, Even some of the older PTO powered spreaders used that ratchet on the wheel to power the web while the PTO only powered the beaters. And then the only speed adjustment on the beaters was how fast you ran the engine on the tractor.
