TractorLinks.com
Re: JD Plow Question and Info Needed
NH8260
02-06-2018 23:27:40
I"ll be using a 107HP New Holland 8260.
Leroy
02-07-2018 07:54:57
 Re: JD Plow Question and Info Needed in reply to NH8260, 02-06-2018 23:27:40
With that tractor I would guess you have lower link sencing so should work, If you had top link sencing like a 5000 Ford then you would need the top link sencing option. I did not haf a Deere but a MF and prefered operation over the 3 point hitch. but plow was just a bit too much for my tractor and did not have good style bottoms as I had the bottoms for extra deep plowing that I did not want to do. I still prefer a pull type then the semi mounted as it still works a lot like a pull type but a fully mounted is easier to hook up. And you can get in tighter spaces with them. Also a semi mount can be a longer more bottoms and heavier than a fully mounted plow.
