Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: JD Plow Question and Info Needed
long green line man
02-06-2018 21:26:53
Definitely F145 ; Looking a colters & it seams to have NU style moleboards thinking its newer A series , Over older H series ; Semi-mount easier to adjust that full mount ,pull type maybe some easier to adjust, Looks to have had front pivot & hitch replaced [dif. paint] hitch is hyd. landing option , looks to be changed or made non operating .. has stubble turners [some call trash boards] ; I'd check [measure] moleboards for alignment , cond. of trips, check if working, manually trip them....
NH8260
02-06-2018 23:32:20
 Re: JD Plow Question and Info Needed in reply to long green line man, 02-06-2018 21:26:53
This looks to have the same moldboards as my 1250 JD plow. They seem to turn dirt over better than the high speed bottoms. As far as the hydraulic landing option, where do you put a cylinder for that? Where is the serial number tag located on these plows?
long green line man
02-07-2018 12:13:28
 Re: JD Plow Question and Info Needed in reply to NH8260, 02-06-2018 23:32:20
The NU [new universal] moleboards came out in "68" ; they seam to work better in heavy, wet, gummy soils.. the cyl. mounts on the two brackets that stick up , with 1 1/8 holes & slid the squre hitch bar back & forth.. this plow has been changed don't look like factory, see pic.. The F145H did not have serial # The A series did from factory ,little glue on tag, but 99% are wore off.. Pic..
NH8260
02-08-2018 16:39:09
 Re: JD Plow Question and Info Needed in reply to long green line man, 02-07-2018 12:13:28
So long green line man, would the plow i'm looking at be a F145H or A?? What would be the value of a JD 1250 3-16" plow be worth? Average shape, paint fair.
long green line man
02-08-2018 20:55:43
 Re: JD Plow Question and Info Needed in reply to NH8260, 02-08-2018 16:39:09
It hard to tell from pic. Looks like it could have been repainted, covering any decal or serial # ;Judging by style of coulters , my best guess, would be an F145 A series, which came out about 69' 70'.. as far as value on 1250, I'd only be guessing , plow prices very Greatly from NW. to Midwest to SE. across the country .... full 3pt mounted seem have good demand.. one thing I do know, a lot for F145's found there way to china , with the High scrap prices.. ,
