Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Re: John Deere corn binder
Farmallb
02-06-2018 20:30:45
IF you don't find one, they should be fairly easy to make. Just move the flywheel all the way back so that the point where the pitman irons attached to the flywheel are at the 3 00 point. Then take the sickle and move it so that the section is back towards the flywheel just enough and then measure the distance between the hook up parts at the sickle end and the mounting parts at the flywheel end. Then move the flywheel to the 9 00 position and move the section away from the pulley wheel the same distance as you measured. IF the section goes all the way across the opening, you've got it measured right. IF not just make the necessary adjustments to where at the 3 and 9 positions the section is all the way over and out of the cutting slot left and right. Good luck.
Leroy
02-07-2018 07:57:05
 Re: John Deere corn binder in reply to Farmallb, 02-06-2018 20:30:45
I think this is what you will need to do. Same way as making one for a hay mower.
