TractorLinks.com
Re: Hesston 530 manual tie system
GarryinNC
02-03-2018 18:28:14
When the twine arm moves out of it's 'home' position, spring tension releases and the twine knife opens and allows the arm to pass through. Part of that mechanism has slotted holes that ride on a set of fixed bolts. See if that is moving okay and also check the rod that the twine arm pushes against when it stops. That rod is connected to the arm that makes the twine knife open and close. We have a 530 and I maintain two more for other people. They are about the most simple round balers made.
Garry
draftx
02-04-2018 07:36:38
 Re: Hesston 530 manual tie system in reply to GarryinNC, 02-03-2018 18:28:14
Garry thanks for the reply. I got it open but its very tight, and is going to need to be taken apart and freed up. Also found out the pickup is stuck and wont raise and lower. The handle is in the hole at the very top. Is that where the pick up is lowest to the ground? I believe the baler sat out with a bale in it for some time. Baler does not show a lot of wear . Any ideas about getting the pick up to move freely. Thanks for your help.
