Author |
[Modern View] |
MFan
01-03-2018 18:15:57
I"d like to replace the front gangs on my Oliver 241 disc with 18 inch notched blades. I"ve checked the local farm stores and Shoup/Sloans and I have only been able to locate notched blades for 1-1/8 square axles, and my Oliver has 1-1/8 round axles. Can I run a disc with square holes on a round axle?
showcrop
01-06-2018 04:56:02
Re: Square/Round Disc Axle Question in reply to MFan, 01-03-2018 18:15:57
And just as in checking load binders after a few miles as we all know we need to do, we know that stress of being pulled can pull one of those discs off a grain of sand on the spool next to it, and suddenly everything is getting loose.
Leroy
01-06-2018 07:01:00
Re: Square/Round Disc Axle Question in reply to showcrop, 01-06-2018 04:56:02
Unless and even if they are all new parts thake them to a wire wheel and pollish them up as just even a spot of paint on new can do that.
farmallb
01-04-2018 20:50:05
IF you have the threads left on the axle after you've gotten the blades TIGHT, id put a lock washer and another onto the shaft and tighten that one down also.
Indiana Ken
01-04-2018 06:09:36
To prevent failure/wear of a bolted joint, the clamp load needs to be greater than the loads seen in service. In the case of square discs on a square axle the axle still needs to be tightened to prevent movement of the discs on the axle. You should be fine just make sure the axle is properly torqued to prevent movement.
Dave in Tx
01-05-2018 23:10:59
Re: Square/Round Disc Axle Question in reply to Indiana Ken, 01-04-2018 06:09:36
properly torqued is the key.. My 1" impact will break the spools..
showcrop
01-04-2018 03:09:05
I think that you would do well to bring a big socket, breaker bar and pipe with you the first time that you use it and plan on stopping frequently to tighten it.
Tx Jim
01-04-2018 03:03:58
Technically to help keep center of disc from cracking/breaking out one needs to keep rd &/or sq shafts tight.
Leroy
01-03-2018 20:53:46
Sure can, no reson not to be able to.
SVcummins
01-03-2018 19:06:32
I think as long you kept the gangs tight it would work
DeltaRed
01-03-2018 18:32:28
Yep,I do,have for years. Also have a 252 disk.15 ft.18-20" blades
MFan
01-04-2018 05:52:34
Re: Square/Round Disc Axle Question in reply to DeltaRed, 01-03-2018 18:32:28
Are you able to use the discs with centers for different size square shafts? Most of the discs available have square holes for 1 inch and 1-1/8 inch square shafts. Kind of odd that there aren"t 1-1/8 round shaft notched discs readily available.
DeltaRed
01-04-2018 07:29:20
Re: Square/Round Disc Axle Question in reply to MFan, 01-04-2018 05:52:34
I try to always use a 1 1/8 hole.Square or round.The square hole just contacts the ronnd at the flats.I,m quite sure there are even a 1 1/4" hole blade there in a place or two.....However the key is to keep the gang bolt TIGHT. like a 4 ft cheater pipe.Shoup sells a 'dura tight' spring washer.They work. However 1 1/4 " hole is the smallest. doesn't hurt a thing.However,I'm sure you are not dragging it over hundreds of acres,only a few. No worries.I drag my 15" over 200 or so acres every year.
