Thomas Cooke
New User
I'm Curious if there are any ARPS Half tracks folks out there with repair experience? The ring retainer tabs that you bend down to secure the steel loops are getting weak and as i use the tracks to plow snow every once in a while a loop ring will push the retainer out and the ring will drop out of the locked position allowing one side of the track to separate. My question is: Can i weld some small mild steel plates 3/4"x 3" over the locks to permanently hold them down leaving only one section to allow removal of the tracks in spring ? Also while i'm here, has anyone installed a wider fatter tire on the bogey wheel to totally support the tracks to keep them aligned? Thanks Fellas and Merry Christmas.
