plow draw bar parts
To start with Merry Christmas to all
I am searching for some draw bar parts for a little genious #8C /"Canadian" Two wheel Lift type plow {{BUT}} I understand that the U.S.
plow had some similar parts. What I am looking for is the cast part that holds the ""Pintal"" quick release part of the hitch on the draw
bar. It is a so called cold cast piece that Is larger than the standard since it holds the extra release mechanism for the hitch that locked
the draw bar to the clevis mounted to the tractor.
""""I Would Like To Locate One In Either Ontario Or Michigan"" since I live in Ontario Canada."""
Unfortuanately I don't have a picture of one available to show [ only hand drawn rough sketches] //// but if some one thinks that they
may have one that they might part with, you are welcome to write and send me a picture of the cast piece.
Thank you Wm.
Well fellows The best I can do ''''sinceI am not good at setting up items on the camera to computer; still haven't figured how to get the pictures off our new camera from the trip[ across Canada in September]'IS TO scribe the piece------ It is 3&/34 inches thick 3 inches deep about 6 inches long and more massive than the standard since it holds the extra parts including fingers that go underneath the clevis that attaches to the tractor and has a horse shoe ring on the furrow side of the part to hold the bottom edge of the rod that comes from the main frame of the plow to the draw bar that enables the plow to lift out of the ground when the trip clutch is activated ///// "" I JUST Atempted to take some pictures off my phone that were given to me showing the '''massive''' part to no avail!
My apologies fellows this is the disgustingly best I can do.
I hope my description is helpful; electronics frustrate me; I am better at mechanical, electrical, & plumbing than electronics.
Any way May You Have a Merry Christmas and a Happy New Year.
Thank You WM.
After I wrote this mornings note later I thought If You would send Your cell or text number through my email which I have enabled I could send pictures off my phone that were sent to me >>> and yes it is just the cast front piece off the hitch or pieces.
So if you could send my a text phone number by email [which is listed] I could return to you what pictures I have.
I realize that the search will be difficult and exhausting to find the parts and also some one willing to part with them.
Thank you again.
Wm.
Dear Mike My email is open f you have text I could send to you the pictures off my phone of the cat hitch part other wise I am stymied as to how to put them one the linen not much of an electronic tech.
Wm.
Thank you to each of you especially Farmallb. Your lead was just what was needed. MacNair has the part in good, no broken shape
Thank you again.
Wm.
Dear Mike;
I did sent back to you asking for a phone number which you could send to me by my email which is open so I could send to you pictures that I was sent via text pictures; pictures of the cast part of the hitch since I am unable to down load from my phone to the computer [ my ineptitude] with computers / electronics.
Thank you happy New Year
Wm.
