1946 BN IHC
To start with Merry Christmas to all
I am searching for some draw bar parts for a little genious #8C /"Canadian" Two wheel Lift type plow {{BUT}} I understand that the U.S.
plow had some similar parts. What I am looking for is the cast part that holds the ""Pintal"" quick release part of the hitch on the draw
bar. It is a so called cold cast piece that Is larger than the standard since it holds the extra release mechanism for the hitch that locked
the draw bar to the clevis mounted to the tractor.
""""I Would Like To Locate One In Either Ontario Or Michigan"" since I live in Ontario Canada."""
Unfortuanately I don't have a picture of one available to show [ only hand drawn rough sketches] //// but if some one thinks that they
may have one that they might part with, you are welcome to write and send me a picture of the cast piece.
Thank you Wm.
Thank you Wm.
