Finishing up
SVcummins
Putting the finish on some plowed ground
is that a rottor tiller sv.? looks good, you must be a long way south of us to be working ground this time of year! we got more freezing rain on top of the snow and ice we already have here this morning, you can skate from the house to the shop.
Se Idaho it?s cold here but this thing weighs about
3500 pounds it?s not a roto tiller it has tines that go
into the ground vertically
That thing must pull a lot easier than it looks. I wouldn't thnk a 3020 had enough poop for that. Anything like a Lely 'roterra'?The old 4020 I once had wouldn't pull it at all.
This is a lely rottera 14 foot when I lifted it up both tires about popped it pulls hard first gear works the snot out of it . When I bought this 3020 I was told the engine was bad and wloildnt pull anything found the number one and number 4 intake and exhaust valves way to tight and injection pump timing way off. The 4020 has its hands full depending how much dirt your carrying usually run 3rd because it does a better job the slower you pull it when your tearing up sod
We?ve had 12 degrees over night for about 2 weeks but no snow yet . Yes it?s scary winter only seems to last 2 months now days we?ve got plenty of water right now but it could get bad pretty fast
