john deere 245 loader
Plowboy1
I'm pulling my hair out trying to find seals/ seal kits for a jd 245 loader. You would think it would be easy! Well, this one must be the "European" model and the pistons aren't standard (must be metric). I've found a few part numbers, but no actual dimensions to compare. Any suggestions? Thanks.
(quoted from post at 16:34:02 12/12/17) What are the part numbers?
DITTO on revealing part # or serial number of FEL. Here's the spec's for rod seal for lower serial number boom cylinder.
The numbers I have found are "AW21846" (I believe this is for the boom cylinder) and "AH212088" (I think for the bucket cylinder) but they don't give any specs.
The rod diameter for both boom and bucket is about 1.570/1.572". The boom cylinder i.d. is over 3" and the bucket id is over 2". Without pulling them apart I can't be sure.
The tag on the loader frame is unreadable and I haven't found any numbers on the cylinders (maybe time to get out the wire brush with the electric drill?).
Thanks for the help.
Probably built in the former JD plant in Welland Ontario Canada, not Europe. Glad you got the info you needed.
I have a JD 2240, I am looking at a JD245 loader for it, does any one have pictures on how to mount the 245 onto the 2240?
