TractorLinks.com
repairing an old hay elevator motor
pilot
11-13-2017 15:59:11
Anyone have any specs on a hay elevator run capacitor ? (Emerson Electric motor115v, 60cy,ph1, 12 amp). 1953 motor but company sold & has no records, no data on the old capacitor. I'd prefer to not have to replace the whole motor. Hay elevator is pretty standard , but mfg. name is unreadable. Plenty of them online but not sure which one to get. thks
pilot
11-15-2017 08:14:00
 Re: repairing an old hay elevator motor in reply to pilot, 11-13-2017 15:59:11
thks Bob , I was trying to match mfd #s .This oughta put me in the right range.
Bob
11-14-2017 20:41:05
The mfd value of motor start capacitors isn't real critical, in general, bigger is better, up to a certain point.
For a motor that has to start a load (such as a compressor) it's more critical, but for your bale elevator which I'm gonna ASSUME you're gonna start unloaded, no need to sweat it.
A 250 to 500 mfd @ 125 Volts motor starting 'lytic capacitor will get the job done.
pilot
11-14-2017 18:52:45
Thanks for the phone # & info. I'll try 'em both. Been chasing my tail on this thing , but getting closer. thks for your help
showcrop
11-14-2017 15:32:54
As Gary and russ say, it is more likely the start winding switch than the capacitor. Probably 100 to one from my experience. Just put some witness marks on the side and the back cover plate, then pull that back cover plate off and you will be looking at the start winding switch. Then go on line and order one that looks like it if you can't just file it or straighten a bent part. Just a year ago I had a two year old motor that wouldn't start. All I had to do was just bend the switch a little.
pilot
11-14-2017 06:34:07
problem with this one is its cracked , almost broken in half. unusable for sure. I definitely need a new one. Most of those hay ladder motors are all the same, rpm ,voltage ect. . either 1 hp or a little less. I'd guess the capacitors would be similar.
Russ from MN
11-13-2017 19:58:01
I would clean the contacts in the starter switch before I would start buying parts. If you disconnect the capacitor and hook the leads together it should start with no load on it, the capacitor just gives it have more starting torque.
pilot
11-13-2017 17:56:08
I don't know, only 1 capacitor. motor is 1 hp, 115 v]
1130Leo
11-14-2017 08:06:40
 Re: repairing an old hay elevator motor in reply to pilot, 11-13-2017 17:56:08
I bet if you call this guy, he can help. Probably can sell you and ship you a replacement, very sharp guy. Barry Electric Company, (810) 985-8960 he rebuilt a motor for me, great resource.
GarryinNC
11-13-2017 17:38:17
How do you know it is a run cap and not a start cap? Or does it have one of each? Any horsepower rating on the motor readable?
pilot
11-13-2017 17:15:44
No repair shops anywhere near us out here. I'd like to get a new capacitor on line, but the specs on the old ones are worn away. Any suggestions on capacitors , that I can order ?
donjr
11-13-2017 16:36:14
Likely just a bad starting capacitor. Try taking it to an elecrical shop. They may be able to replace it, and you're back in business in fifteen minutes.....
