I have an old George With 7 foot snowblower, The gearbox cast iron casing is broken beyond repair. The box is a Durst A11, and
so far as I can tell is no longer available. I did find a usable gearbox in another old blower. It's made by Dana and has a number 40 cast into it. I can make it fit by making a new main shaft and doing a little fiddling around. (I have a well equipped machine shop at home)
Does anyone know where I could get oil seals for either of these gearboxes? They are an oddball size. The 2 main shaft seals are
69 mm OD and 1.5" ID by about 3/8" wide.
The seal for the cross shaft is 69 mm by 1.75" ID.
I would appreciate any help with this.
