Texasmark1
Stem crushing implement, drag type, steel drum on top, rubber covered like swathers-haybines on the bottom. Sickle cut thick stemmed crop then come back with this to crush the stems....integrated into swathers-haybines of later years.
Question is, for road transport, I can't find any way to raise the rollers. 3 adjustments: Side 2 adjust tension between rollers and small one at front changes the drawbar angle for larger or smaller WWs. It does nothing to raise implement.
Thanks for your time,
Mark
Mark
