John Deere MX10
peteK
New User
Broke a gearbox shaft on our MX10 Bushhog. Had less then 300 hours on it. Hit a small pine stump. That should not have even caused an issue. As I had hit it with my Woods 7ft finish mower. But got the shaft on the MX10.
So put both shafts in it. Hope to never do that again. Stump jumper on the good shaft was a bugger to get off. Had a chain and 30 ton jack on it. And still not moving. Stuck a torch in one of the holes and started heating the collar on the stumpjumper. And it popped off easy.
So now left with extra shaft, may try to find a single gearbox bushhog. And fix it with this extra shaft..
After doing a search a few weeks ago. Found where lots of peole had this issues. Sad JD did not take care of the owners.
Pete
As I posted this Summer I am very happy with my MX-8. Hit the rail in the ditch and all it cost me was new blades. Maybe the third time you hit that stump will be the "charm"---Tee
Sounds like yours had the new updated gear boxes. Mine was made the first year they came out. Few years later when JD changed gear boxes. No more issues after that.
Wish I could find one of the 8's for my smaller Kubota.
Pete
