JI Case disk harrow
I'd like to hear your thoughts on the JI case disks
There is a model F21 for sale near me I think it's 21' wide
Are parts still available for them and do they leave the ground pretty level also how old is it and does it have sealed bearings
Thanks for any thoughts
I have a F-21 Case disc.Think it is 24' wide. More of a finish disc, does a good level job. Bearings and replacement discs are found at most
bearing houses and Runnings or similar farm store for discs. Not gonna cut 12" deep, but still a good machine.
(quoted from post at 21:42:00 10/11/17) I have a F-21 Case disc.Think it is 24' wide. More of a finish disc, does a good level job. Bearings and replacement discs are found at most
I have a small JI Case XRH offset harrow that does a great job. I have found most parts at Agri-Supply. The only parts I can not find are wheels. If anyone has information for a source it would be much appreciated.
Im looking to use it as a finishing disk
I want something that leaves the ground nice and level to run behind the offset disk and ripper
I currently have a Taylor Way 11' finishing disk it is a little smaller than I'd like and it dosent leave the land as smooth as I want even with a float
I imagin the Case disk would go as deep as the Taylor Way or am I wrong
