IH 4000 HAYBIND
jlunde
New User
hdy. hose blew left side drive motor,lost all oil bi time i stopped moveing.replaced hose added oil, left side will not move called dealer he sugjested jacking up machine running to get air out of system,tried didnt help.any ideas what to try or do you think motor went bad from running out of oil?
I would be more worried about the pump.
With no oil the motor will stop turning but
the pump will keep grinding away on the
valve plate until the engine is shut down.
I'd check the return filter for brass
contamination.
