trying to identify this plow and mower
ronztoys
New User
Recently bought a Farmall 450 and got these with it, trying to figure what model numbers they are , so I can try to find parts for each. Any help is appreciated. the plow needs moldboards, a coulter and a trail wheel. the mower needs minor items.
Both are IHC fast hitch implements, I have no idea of the model numbers. I have an idea they would be 300 -400 vintage.
Thanks for replying back, I thought they belonged with the 450 in the era . Need to find parts for both . I'd like to get them working again
That plow has Plow Chief bottoms,plow points are NLA if it had Super Chief bottoms those parts can be found.As to model number maybe 311.Scott
Steve, Was the 4-F43 a 4 bottom plow only or also available in a 3 bottom version? Or maybe someone cut down a 4 bottom to a 3 bottom. For model numbers for the mowers search CaseIHParts for a model 24 or model 28 plow. The parts diagrams should help you identify your mower. Those are the most likely mower model. Hope this helps.
I was thinking it was a 4-F43 plow , I was thinking it had plow chief bottoms, but wanted to be sure I may be calling for a manual and talk to you on the rest .
I checked in CaseIH parts and found no listing for the mower in either model number 24 or 28, thanks for the suggestion WES
Newer plow bottoms that parts are available for will bolt right on those plow standards.
