Continental Belton Post Hole Diggers
Pappy73
New User
I have a Continental Belton Digger, it has an AC snap coupler style hitch. I need to convert it to a IHC fast hitch. I need either the parts for the fast hitch or measurements to build a fast hitch for my 706 IH tractor. Any information would be greatly appreciated.
I take it you already have some FH equipment. then you have some prongs to make a traceing from.Then cut out a set of prongs from flat steel. For that light application,3/4" would suffice. You have the hitch on the tractor,you can measure the width between.Next you can figure out how to mount. Easy way ould be to make the prongs into a 3 point 'adapter' arm. Put some pins on to the digger and it should work.seen several of those old diggers with adaptions for hitching Should be fairly easy.
I have what you need. I parted an old CBD that had IHC fast hitch and I kept the IHC stuff It is here in Ohio. $50.
info here, was like this
https://www.worthpoint.com/worthopedia/vintage-continental-belton-co-texas-1727715916
to R Aiken that's great I will take them my number is 937-725-2455 call me or text me with a good time and your address and we'll meet
