International c-21 or c-24 question
Good afternoon yesterday tractor folk. I have a question. I recently came across what appears to be a C-21 or C-24 fast hitch mower and the hub bearing and flex plate are shot. I have a manual on order for it but in the mean time I am wondering if anyone can give me the part number so can see if case or a local store may have the parts needed for this old mower. I know this is general in nature but looking for any input. Thank you for your inputs.
I am assuming the flex plate is the part that connects to the pitman stick. The plate number is 455 311 R1 and the bearing is a St 314. The felt grease retainers are M32 933. The felt retainers are M32 779. The entire assembly is a D32 936 for a 1953 mower and ME32 936 for a 1953 to 1954. I don't think the grease felts are available from Case/IH. If I remember right several years ago I was able to get them from a local equipment place an IH parts guy told me to call.
thank you for the response 300. Sorry I didn't get back sooner. I ordered a implement manual and I definitely have a C-24-P mower. It has the bushing hub instead of a bearing type though. Thats what I get for assuming a bearing was out before I actuallly pull it off though... sorry for any inconvience. Do you know if the bearing hub assembly and the bushing hub assembly are interchangeable? I would assume so since they are mounted to the same pin on the flywheel.
