Texasmark1
Jim,
Bearing on lower main drive roller, on the chain sprocket end, is knocking. Shot it with some chain lube yesterday, with PTO engaged and got it to stop. Apparently dry and seals must be leaking to let in the chain lube. Now that I know that's the one knocking and it responds to lube, leaving be and lubing prior to use is an option.
I have an assortment of tools and work alone. How much of a hassle is it to replace that bearing and would you do me a favor and post one of your IPBs with your info. JD PN would surely help too.
With haying finished this year for me, it would make for a good winter project.
Good Haying!
Thanks,
Mark
Good Haying!
Thanks,
Mark
